Rocket Scientist said: I must take issue here. The proper sequence is, install final drive, leave the four bolts finger tight. Install wheel and axle, torque
axle nut.
Then torque the final drive bolts. The next time you have your final drive off, you'll notice it has clearance in the bolt holes I.E. you can rock it back and forth some. By tightening the axle first it puts the final drive in perfect alignment with the axle, so it's not putting a bind on the rear
wheel bearings.
