I wouldn't. Assuming your cooling system is working properly there is fluid that moves between the bottle and the radiator. The stock ones are butt ugly though
Grampy it should be kept but any container that will be ok with heat let's say same heat as a mug of tea and about the same size will do you ,just need the pipe from just under the rad cap to be under the water level and a vent higher than the level so you don't form a vacuum when the coolent gets sucked back into the rad .mount it where you want/convenient, I posted a pic of mine earlier in this post .
I've seen several photos on here with the K&N mods and a lot of them show a chrome overflow bottle in the picture. Does anyone know who makes those, part number, etc? Planning on putting the filters on and can't stand the ugly plastic one (hell, can't even see through it anyway!)
Thanks!
I wouldn't. Assuming your cooling system is working properly there is fluid that moves between the bottle and the radiator. *The stock ones are butt ugly though
