Change Those Fuel Filters
Hummmm....
Shows how little I know about a Rocket III...It has a fuel filter:eek: Where in the world is it at...:confused:
Clean injectors?????.........how to clean injectors....Remove and scrub with a tooth brush....Maybe????
My Rocket has (not sure) around 16K Plus--Minus Some...........I would have to put the battery back in and see one day.
53 K on the 2001 K1200 LTC BMW
It is in the fuel tank Joey. attached to the bottom plate you see when you lift the tank.
It is in the fuel tank Joey. attached to the bottom plat you see when you lift the tank.
Yes you can use a toothbrush. But it works better if you use a can of carb cleaner and a 9 volt battery. Google it. It is really easy.
Do What????:eek:
Inside the fuel tank.........Dang:confused:
That is about as dumb as where they put the oil filter in a K1200 LTC BMW
Inside of the engine crank case:thumbsdown:
Here is a look at the regulator, pump, and filter unit assembled Joey
the pump is in the back bottom before the filter.
It is possible to take the filter out and exchange it from the bottom rather than the top though. ;)
I taste vomit in my mouth! Did some actually destroy a tank for an image? Was there an awful dent in this tank? What the heck did someone do to this tank? THE HUMANITY!!!!!
Rick you do not know Scott very well. He will do anything to help everyone on the forum. He went straight out to his bike and cut a hole in it just to show me where it was :eek:
i have about 32000 miles if i run premium gas what miles should i change the gas filter. she still runs strong still she hits the rev limit.
