BigNorm
Boobie Inspector
Minden, NV, USA
2014 Rocket 3 Touring
We have established that we can create as much power and thrust as a, well, er, a ROCKET! Is there any aftermarket calipers that help slow this beast down in a hurry better than stock? As always thanks. Love and kisses. NORM
Pretech makes a 6-pot caliper for the Rocket. You'll want to check to ensure ABS compatibility.
Brake Calipers | Motorcycle Brake Calipers | Racing Brake Calipers | Engineering | Pretech, Reading, UK
But unless you're taking your Rocket to the track and doing repeated high-decel braking and having your brake fluid boil, you should ask yourself exactly what you're looking for. The stock brakes are good enough to modulate and lock up the wheel / engage ABS, so what would be the benefit of larger brakes in even the most spirited street riding? Larger calipers and/or discs just add cost, complexity, and increase unsprung weight. In stock form, the limiting factor in deceleration is the wheel friction with the road, and the weight.
Use the Lotus philosophy: "Simplify, then add lightness." You can start by replacing the stock exhaust system to drop 50 lbs.
among the best brakes ,, Bheringer makes some very special brakes worth a look
Agreed. I feel my R3R's brakes are very good for my aggressive riding style. Unless I am going to bring it to Lime Rock or Loudon the Brembos work perfectly.
No problem locking the rear and the two disks up front seem to be more than adequate to bring the beast to a stop even with my current stock pads. EBC HH double sintered when it's time for new on the front. Already have them on the rear. I don't have ABS.
So I have a 2014 R3R and used to have a 2012 R3T and I find the breaking on the Roadster significantly better. That could be other factors like position and weight distrubution (it could also be that I'm 100 lbs lighter now than I was before), but I found a significant different. I ride agressivley in the twisties and the breaks are more than I need, in fact I have to be careful when I have friends behind me and I forget that they can't break nearly as fast.
First off, congrats on the huge weight loss! Stock, the '12 R3T is 869 lbs vs the '13 R3R at 807 lbs., which is a 7.1% weight reduction. Adding in a 100 lb personal weight reduction should net huge improvements in acceleration, handling, and braking.
That makes sense ... and thanks .... unfortunately have put some back on but working on that again ... the battle continues
The EBC Double HH Sintered pads made all the difference in the world for me. Without ABS I can lock the front or back wheel almost anytime. I thank God he gave me good brake application technique.
