Beetle Bag Help???...Really..I am flummoxed!!!
NativeOne
Texas
Gary: I don't have stock pegs. I removed them after the bags were already on there! All you should have to do is place a threaded bolt the size required and a spacer, I'm thinking about a 3/4 inch spacer in the hole where the pegs would go, tighten the bolt in order to secure the bracket that holds the Corbin mount kit. That mount only needs to brace the Corbin bag bottom and seat the screw that holds the bag securely in place in the bottom of the bag! I would suggest screwing the bracket to the bottom of the bag, then determine the length of the spacer you need.
My rear passenger pegs are Kuryakyn and I mounted them by drilling through the swingarm and the swingarm cover!
Native One
Take your extenders and passenger pegs/boards off, completed the install of the bags and then see if your extenders and pegs will fit. The corbin brackets bolt to the same spot the extenders/original pegs bolt to on the bike.
Also Gary, you do not need to use that bolt that goes through the passenger pegs, it is totally unnecessary as when you tighten up the bolt that runs through the center, it is sufficient to hold the bag weight on the bottom as you have the two bolts holding it on the top.
Native One
G-Man,
If you need any help or pointers just PM me, I learned a few things on how to do it better after doing mine.
