There is no L trim table in TuneECU so you can’t use trims to change the L tables. The easiest way for me would be to use Excel. Export the 3 L tables. The exported files are tab delimited txt files. Import the L txt file into Excel. Put the number 1.06 into an empty cell. Copy it. Highlight all of the fuel values in the table. Do paste special. Then check “multiply”. When you hit OK, all of the values are multiplied by 1.06. Delete the 1.06 from the cell you put it in. Save the file. Import it back into the L table in the Penner map.hi @EskimoPie , can you tell/guide me how to """ add 6% fuel to the L1/L2/L3 table"""
