I removed the stock components including the rear tire fender. Installing fender eliminator...however the wiring from the stock aparatus remains on the swingarm. there is also a wiring underneath the rear brakelight. Can anyone please steer me in the right direction on which ones to wire before I blow 50 fuses??? thank you see attached
When I moved the indicators to under the rear lights, I just rerouted the one from the swing arm up behind the side panel and through to the rear. I did notice the connector under the seat/rear brakelight, and like you wondered what it was for... it's for the My Triumph Connectivity Module, so don't use that as it's connected to the ECU/Instruments.
