Windshield / Fairing question
On my Corbin I replaced the shield with a 13" which is still about 2" too short for me.
I normally take it off for the summer.
Next time it's due for replacement, check out Cee Bailey's stuff. They will make you one as tall as you want and tinted to match your fairing. I was impressed with their optical quality since I look through it. This one is 27" overall and 15" from the chrome cross brace. I've had it 150mph and it never complained, seems it's not only stronger than factory, but also just a little thicker.
It's the same acrylic used for their aircraft replacement windows.
Well after reading all of this.. I do have a solution to all of this sitting right next to my Rocket in the garage. It's called a Triumph Trophy 1200 with a taller Clearview windshield with the vent built in.. lol It also has 20,000 less miles on it than my Rocket does.. :)
I need to resolve the range problem I currently have with it.. I can't tell if it's fuel related of if the ECM is overheating.. but I need to pull the tank remove the petcock and clean it, replace all the fuel lines.. probably pull the carbs and clean out float bowls.. although it runs really, good until it dies.. which is usually about 30 minutes into a ride.. lol
