I remove just the top end of both shocks unless you want to remove the whole shock for detailing or services. With the Valkie it was the same procedure.
Remember to have correct lube for the splines. After tire is off... the final drive comes off. I cleaned mine with a few blasts of brake cleaner a tooth brush and shop towel. This is a good time to replace the oil in the final drive. Open it up and let it drain overnight.
Best technique I've found for getting the rear back on is is to get my legs in line with the wheel whilst sitting on the floor under the bike and use my legs to hold it up and get it seated on the spines, then don't breath until the axle is through
I very much like @Claviger explanations for all kind of mechanical procedures logical and simple,however when I try his maneuvers I always screw up somewhere along the end ...
I often omit simple things.. like don't let the caliper dangle by the line, you need to lift the bike to get the tire out from under the fender, etc haha.
