What is the newest/best tune for the older Rocket Standards/Classics ?
What is the newest and or best power output tune for the older Rocket Standard and Classic with just TOR's added ?
Claviger's Domination tune with O2 sensor off would be a good starting point to run as is or with a PC3. It is very similar to what I have found that works well. Changing the L/F switch over point either higher or lower can affect throttle crispness if you prefer other than it is. With the O2 sensor on the ECU will adapt to the a/r table if possible (I find this messes up otherwise good tunes so I would disconnect and plug the hole with an oil pan plug and copper compression washer of the right size from your local auto parts store.)
These tunes are posted on this forum: do a search for "domination"
