Gregger
I've never had a Triumph pump apart but that looks like a mechanical seal (spring loader) which usually has 2 parts. The 2 separate parts seal with pressure against each other, then against the housing/shaft and impeller. Not sure gluing them will work. Is there another seal between the bearing and seal support plate the mechanical seal was up against? There are numerous "how to" videos on replacing different water pump mechanical seals on cycles.
Here's one for a Kawasaki Z800. Forget the part about the oil pump.
Don't know why Triumph hasn't included a parts list for this!!! It is serviceable.
