Roscoe
Chaplain
Hard to tell but it sure sounds like a connecting rod spun a bearing. Do you get a double knock when giving a little throttle? I wouldn't run it for long if it is a bearing because it will chew up the crank and rod end.
Pull the filter and cut it open to check to see what's inside. If it is a bearing, you should see some swarf....
Motor still runs smooth as a babies bum.
