Hi,
In advance, Sorry for my bad English but I hope you understand me.
Please try it without VCP (
Virtual
COM
Port).
Cable plugged into the computer and then:
Open the Device Manager and look under "USB" the "USB Serial Converter"
Double click on "USB Serial Converter" in the new window select "Advanced"
Now remove the check mark from the checkbox "Load VCP" and close Device Manager.
Remove the cable from the computer and plug it in again.
Connect the cable to the bike and turn on the ignition (not engine running)
Start TuneECU open and an OEM-map.
Now select in the menu of TuneECU, "ECU ------ recovery," should start the recovery process.
It is possible that this process must be performed repeatedly.
If this way does not work, then wait on the follow message from TuneECU:
"ECU is connected but not responding. Run the ECU Recovery ?"
When the message appears, click "OK" and wait until the process is finished.
If the process is completed successfully, you must follow the OEM-map again loaded onto the ECU.
I have also a cable from "Lonelec" it works correctly for me.
BR, Tom
Addendum:
I use the FTDI driver version 2.08.14 and TuneECU version 1.9.9
OS: Windows7 32bit and Windows XP SP2
Your problem also had a user in a German forum.
This user had an error in the wiring harness his Rocket, this wiring harness has been replaced under warranty and since then everything works as it should be. In his case it has been a Rocket Roadster.
Thanks for the map info guys.
Seems I have fallen into the same trap as others. Downloaded map no problem then went to upload new map which failed at about 10%. Result is bike now won't start. I tried all the advice so far. Remove fuse/leave fuse. Anti-Virus removed, full charged with charger attached (is this the same as having an external car battery attached?). Just wondering if anybody had any recommend advanced settings for the COM port that might improve communication/transfer.
Running Windows 7 x64 also tried on XP x32. No joy on either. I also bought a KKL cable from Lonelec.Cheers
