Power-Tripp
Turbocharged
Software and tunes - Link Removed
Installation instructions in various languages - http://www.tomhamburg.net
FTDI drivers - Virtual COM Port Drivers
Cable - Link Removed
Or try Ebay for cheaper prices.
Simple over view:
1 - Download latest version of TuneECU. Unzip into new folder.
2 - Download key. Unzip into folder above.
3 - Download FTDI chip driver for cable.
4 - Order OBD-USB FTDI cable for VAG (VW Audi Group) and install drivers when cable arrives.
5 - Download any/all related maps for your bike.
6 - Open map and connect to bike (key and kill switch on, engine not running).
7 - Under ECU at top, select Read Map. This will upload the map from the ECU.
8 - Save the original map with a new name. Preferably in a new file for your future maps.
9 - Open map file you want to load to bike's ECU.
10 - Download map to ECU.
Now, start the questions on how to use or modify maps below.
Should you have issues connecting to the ECU, make sure your battery is fully charged FIRST. Then make sure key switch is ON and kill switch is ON.
YES - The TuneBoy cable will work with TuneECU.
NO - The TuneECU cable will not work with TuneBoy/TuneEdit.
Simple over view:
