Tune for 2011 Touring with K&N pods and Tours
Will any of those work with TORS???
Like 20235Map_Wolle_144PS_SEC_100.hex or R3T_Jardines_20366_base_Jan2011.hex
This tune is for aftermarket exhaust and triple K&N:
20258 R3T-TOR-3KN-Sub rem Tovami.hex
But where did it come from? Is it from a custom dyno?
If it's for the Touring with TORs, the only map I see on the TuneECU site is the one I linked above. For standards, there are other tunes.
We are kind of limited to options with the touring,,,,, being the redhead stepchildren of the Triumphs.... :rolleyes:
That is why I went with the PCV/AT.
bonecarver not what I wanted to hear...
dougl where did you get that map? Wonder if they mean aftermarket exhaust IE tors.. are the jardines that much different that the tune will not work with tors?
Found were the tune was... Sorry was blind...
Rocket III Touring Aftermarket exhaust, Dyno run at Tovami Goes – Pays Bas for a R3T 2008.
- Triumph TOR exhaust., - Subsidaries removed., - KN triple filter installed ,- No Lambda sonde, - Gipro,
- Max power: 147.7 Bhp at 5756 rpm, - Max. Torque: 237.5Nm at 2332 rpm, - Speed limit: 240 Km/h,
- Speed Adjust: - 3,9 %, - Thrtmo Fan: 95 °C, - Rev. Limit: 6800,
Can someone tell me what lambda sonde is? and also will I have a problem with no Gipro?
Thanks looks like that will work for me.
