Ok so, two posts in a row, but since it's a technical discussion, I figure it's probably a good place to mention this, as people might get the idea that TuneECU makes PC-V unnecessary for Rocket 3s.
TuneECU has a maximum value that can be set in the tables. There are work arounds, but, I am not sure if they actually give more fuel or are just methods to force a bigger number in the table and the ECU doesn't know what to do with it.
Because of this maximum value, there is a limitation to the amount of horsepower that can be tuned for using exclusively TuneECU. I haven't found the exact number, but, I suspect the 160-170 range is probably around that number IF you stick with the stock injectors and pump.
This is one of the main reasosnd Tuneboy is a superior choice for high power bikes. Couple the addition of all the Tuneboy features for a tuner, and it's much more attractive than TuneECU.
PC-V is of particular interest because it's easy to find PC tuners, tunes can be edited more quickly than TuneECU or Tuneboy, can provide better table resolution than the other two options, can be leaned/richened on the fly with a POD-300, provides superior data logging to both TB/TECU, and a few other reasons.
I believe this is why most serious big power bikes run the PC-V+Tuneboy combination.
Then there is the whole reason I pulled all my tunes down, linked in my signature.
