atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 3,409
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
Hitch is model #191 for Rocket III from www.hitchusa.com
The hitch attaches to the passenger peg bracket. You'll have to swap out the e-clip pin and sub a bolt and washer. I used a 7M bolt about 2.5" long plus a lock washer. The hitch doesn't allow the peg to go up and down unless you add in a spacer. I used a 1/4" thick spacer I had laying around. You can also just sandwich in some washers.
The upper support brackets are held on by the rear fender support. I used a 8M X 1.25 90mm long plus flat washer, lock washer and nylon insert nut (No I don't want to have that nut vibrate off).
The way this set up it doesn't interfere with the suspension (good because I didn't want to put the stockers back on).
It centers the ball pretty well.
You can see the trailer is held out pretty well. The reason the trailer is tipped up is I'm using 13.49" shocks (1" over length) that will reduce some when I sit my fat butt in the seat.
You can see the offset from this angle.
Bike and trailer together first time.
