1) Caberg Duke Visor
2) Nexx XD1 Visor
3) KTM and R3 screens and headlights.
Done, done and done.
Did the tail-lights and indicators too. And the KTM mirrors.
This is going to sound obvious - but: The cleaner and more pristine the surface you use this on - the better the effect. I know from experience that nano chem can be used through the "little but often" maxim to fill slightly more visible scratches etc. But if there are deep scratches or chips - this is not going to magically fill them.
I have today used both sprays - AMP on top of TLC2. Separate "wet" application cloths - shared final "dry" buffing cloth. The AMP has a very distinctive smell - the TLC2 to my nose is neutral. Once applied and dry/buffed - there's no perfume.
The Caberg visor seems to have benefited more than the Nexx - despite being older. But the Nexx inner sun visor seems to have done better (a caveat - later)
The R3 screen has responded remarkably to treatment. But it comes with an anti scratch finish OEM. The Ktm fly screen is simply soft acrylic - and that shows.
Ktm was clean-ish so I went over the gloss finish plastics and tank paint - Very pleased. I think there is too much risk of adding scratches to the R3 paint and Granny Guzzi, so I'll give them a soft rinse over ( to get rid of dust etc) before attacking. I have done a water test - water does indeed simply run off leaving no spots etc.
CAVEAT - I deliberately did NOT do the inside of the visors. This is where the scratches are more visible. I wanted first to test and establish demisting or otherwise. I'd say it's not going to help much with breath vapor on visor insides. Unless you have excellent airflow. I'd go as far to say that, based on today's tests in the garage, it might actually enhance misting. And I'm not entirely surprised. They are opposed solutions.
The best anti-mist I know is KLAR-PILOT COMFORT glasses cleaner from Germany. It's used by a lot of SWAT-type fellows inside their riot gear. I was introduced to it by a officer from Dutch special police forces. I little goes a long long long way too.
This is something - imo - to apply as early as possible and simply keep using. If I was, for example, stuck at home, bored stoopid and with a shiny pristine sparkly red MV sat there. I'd be all over it with this stuff.
