I blast it for a couple minutes with a heat gun (hair dryer type), helps loosen the glue. If there is glue left on the tank, use a little more heat and dab it with the glue side of the sticker, that will pull off the rest.
after peeling of the sticker, you can apply a light layer of peanut butter for about an hour then the glue will come right off. preferably creamy/chunky may scratch.
Opinions are welcome on this thread, but it must be your own. Do not attempt to legitimize your opinion via some other writing, law, teaching, similar event, or source of information.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
