Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,961
- Location
- Ride
Just now reading the post, M8.
First, I thank you for thinking of me!![]()
Very interesting design, indeed. I'm wondering about the angle of that fixed square hole and having no adjustment to bring the plate down closer to the fender.
Coincidentally, I have been seriously pondering purchase of a Corbin solo w/back rest.
If I pull the trigger on a Corbin, I'll have to try and design/fabricate something similar.
There appears to be a black worm screw rack angle adjuster at the end opposite the square hole that engages a ramp/rib fillet underneath the rack. Pretty sure the R3 with one fitted below is using the short bracket version.
EDIT: LOL just scrolled down the eBay listing to find:
This is a Luggage Rack that quickly and easily mounts to Corbin, Mustang and other brand passenger back rests that uses a 5/8" square post OR 1 1/4" to 1 1/2" wide flat post.
There are no brackets to attach to the fender that would clutter up the clean look of your bike!
This Luggage Rack is made of 3/16” thick steel so it's very strong!
Shield measures approx. 9.5" W x 11.5" L
Available in Chrome, Powder Coat or RAW (unfinished) so you can paint it to match your bike.
Installation is so quick and so easy we have a patent pending on the design! Just pull the passenger backrest out of your seat and insert the post into the luggage rack mounting stem, then back into the seat. Tighten a couple set screws and adjust the level! It literally takes less than 1 minute to put this on and take it off.
The screw at the bottom allows you to adjust the angle of the luggage rack to level it for different seat post angles.
Optional Stems:
- LRS3 - Wide Luggage Rack Stem for 1 1/4" or 1 1/2" wide backrests such as on Mustang and some Harley Davidson or Victory seats.
- LRS4 - Short Luggage Rack Stem for applications where the fender is too close for the LRS1 Standard Stem or you just want the rack closer to the seat, as in the picture above, on the blue M109R.
Notes:
- Recommended load capacity is 20 lbs. however many customers have reported carrying MUCH more with no problem.
- Make sure your back rest post is secured in the seat.
- As always we recommend the use of a thread lock compound such as Loctite on all threads to keep them from vibrating loose.
