kjones256
I installed a set of risers that are roughly about 3-4" high with about a 2" pull. Unlike the OEM which has a bolt with an allen head coming from the top and a nut on the bottom, these had a hex bolt going up with a pressure washer and the large flat washer. After tightening the bolt with a ratchet I got concerned that the handlebar rocks back and forth a bit. Is that normal? Thanks for your responses.
