ant
Turbocharged
Hi,It's time for the rockets service,oil and filter,plugs and usual checks.I was thinking about changing the fork oil but have been checking the work shop manual and there are 3 special tool required,i am thinking that the 3880160-T0301 is a bit over kill and am sure that you could get the same result using a stick.It looks to be a more complicated job than old type forks,ie undo the drain screws on the side of the lower fork legs and pump the forks to remove the oil then replace the screws undo the top nut fill will required amount of oil replace the nut...easy peasy lemon squeezy lol.
Unless somebody knows of an easy way off changing the fork oil on the rocket..I have heard of people removing the damper rod bolt and seal and draining the oil from there....
The sun is out today so might do a few miles and get stuck in to servicing the bike when i get back..lol
