I recall comments by HellFire (RIP) and others that with 'standard' (incl TORs) tunes, the secondaries change a/f mix by adjusting air flow ie that there was no extra fuel but rather a choking effect to make the mix richer. Removing secondaries therefore should make the bike run leaner at certain points in the range (when secondaries would normally not be 100% open), which you overcome with PC/Dobec/tune. The extra oomph comes because of the less restricted flow and more fuel when you need it, and the extra responsiveness comes because there's no set of butterflies to have to open when you turn the throttle.
