warp9.9
Pocałuj mnie w dupę
Has anyone tried the Rotrex Supercharger on their Rocket yet ? If so is it worth the money ?
What cost :?:RiderRocketman said:I suppose I forgot to include some basic info... You get around 250 horsies with the latest setup. You also need Tuneboy for the lastest supercharger tune. Before Tuneboy, output was at 238 HP using PowerCommander. The turbo kit output about 205 HP but it's been almost two years since those numbers came out. They've probably optimized a few more ponies since then but unless an intercooler or other engine mods are used, the turbo's output will be less than the supercharger.
The stock air filter setup that TTS provides with the supercharger kit is not meant for running in a lot of rain. The filter is completely exposed so I had Richard build a rain cover for my setup. You might want to do the same if you plan on running wet. I'm not sure how weather worthy the turbo is but far as I know its air filter is also fully exposed though it is more covered behind the engine where the catbox goes.
I'm not certain on the boost level for the supercharger. Can't be much more than 5 or 6 PSI. I'll have to ask Richard at TTS on that.
Far as riding it though, it's kinda like that big joy you had when you first took your Rocket home and wrung the throttle. That 'holy cow!' it's fast realization, grinnin' and laughin' the whole darned time. If you've had a Tuneboy upgrade then you've gotten a little sampling of what boost tastes like. Taking away your Tuneboy feels like you've lost a cylinder. Putting in the supercharger feels like you gained three more.
The front gets real light launching at just three quarter throttle. To be honest, I'm **** afraid of the power she makes to go WOT in a low gear, but I can tell ya WOT at 60 MPH in top gear will have you in triple digits in a few seconds. I gotta do some more accurate testing when I get my bike back running. Before boost, my best top gear roll-on at 60 MPH was around 90 MPH in 5 seconds.
She does want to settle in at a higher speed than before. There's just so much power on tap, it's very very easy to go a little too fast. Gotta keep an eye on that speedo better if you want to avoid those tickets.
Also FYI, Richard is designing a new combined cam sprocket/supercharger pulley drive to eliminate any possibilities of the stock cam sprocket failing again. However, this complicates the install because the cam shafts have to be lifted to put in the new cam sprocket. I'm having my dealer do this when they look at my valves and cams.
Far as pics, I posted my finished install along with another TTS one here:
There are some more pics of the parts and info in this older thread:
I have a few pics from during my install but haven't had time to process those yet.
I got my kit straight from TTS in England. Paid with wire transfer and got the parts in a shipment. You get most everything you need except the tools - Rotrex blower turbine, boost overflow valve, mounting brackets and hardware, air piping, air filter, belt pulleys, belt, crank shaft extension, new fuel injectors, wires (for new injectors and relocating the air temp sensor), oil cooler (for blower turbine), hoses, clamps, tranny oil (for turbine), drill bit and tap to do the crank shaft and install instructions. The instructions are kinda sparse but Richard at TTS was always available to answer my questions. You will need a larger, heavy duty 1/2" power drill to drill the hole for the new M12 crank shaft bolt (stock one is a stubby M8 ). Your typical power drills are usually the smaller 3/8" size. You'll also need a tap T-bar tool to tap that big hole you make in your crank shaft.
It is a big project but once you're done there isn't any satisfaction greater.
[3] Effectiveness. The supercharger gives more power production since it runs off the crank instead of sucking power from the exhaust flow.
