TURBO200R4
stand up straight and grab the world by the a$$
The starter relay is a 5 terminal relay while the others are 4. I'm not sure the 5 will fit if it's only a 4 terminal socket. The relays are cheap in my opinion...it seems only around $12 so I carry one of each type for just in case because you aren't going anywhere with a bad one. You might survive without the fan relay in cold weather. It has been reported, all have a protect diode to prevent transient spikes. In a pinch, a standard relay of the proper amperage from an auto store could get you home. I would swap around one of the stock relay into the engine management spot if that one is bad. Put the new auto store one in the fuel pump or fan position.
on my 07 i think the 5 terminal will work on all do not know about the later models.
