Rocket pulls to the left when taking hands off bars since lowside last year
tribal
Turbocharged
Fairport, New York USA
2005 Rocket III & 2015 Rocket III Roadster
Update: while doing my stator and lifter parts repairs we tightened all the engine mounts to spec with the bike suspended on hoists.
It didn’t correct it 100% but seemed to help.
I also put new tires on so that contributed to the improvement.
Both of my bikes have the forks pushed up further into the triple tree to lower the front. I measured the length showing at one point and they were the same.
I may try sonnies fix
Rocket_Rider
Sydney Australia
Rocket 3 Touring 2018
When I highsided my touring last year I had a front end wobble. Was convinced it was the frame - but after frame alignment check it was found to be straight. I disassembled the front end and reassembled it carefully following the workshop manual.... no more issues. I found the forks slightly out of alignment, headstock not torqued to spec and a bunch of other minor issues with how the stealer ship had reassembled it.... bars and forks out of correct alignment will cause a pull to one side?
a frame check should be quick and relatively cheap... if it ain’t that, I’d be going over the whole front end myself.
Good luck! Hope you find the answer soon.
tribal
Turbocharged
I thought I had it figured out.
I thought my Left analytical "Spock" hemisphere of my brain was too heavy causing the bike to pull to the left but I took a quick test
and it shows that my creative "Captain Kirk" Right side is equally balanced.
Similar threads
Similar threads
AdBlock Detected
I've Disabled AdBlock
