DEcosse
If it's no Scottish it's CRAP!
If you have headlight relays then is just the pump current (also the starter solenoid current when cranking - that is about 10A - but that is short duration)
So most likely the crimps are poor and the pump current is enough to be doing the damage
If you divert that pump current away from the key-switch connectors that will help
(but you may want to re-terminate that white/blue wire in the connector regardless)
