Replacing toe peg on shifter
I have seen a cover for the peg for guys that dont want to mark up their loafers. Check the inner web I am sure you will find one.
Yeah I seen those leather shifter covers pads they're in the running thank you very much for the information sir
It's just the rubber seems really cheap on the OEM and I guess I was looking for solid metal maybe a little longer I'll just look around, Maybe I'll find something on fleabay or somewhere thanks for the info
ok I messed up I was not thinking the Roadster was any different from the standards and classics which do not thread on. And so far do not wear out.
Heel shift....
Yeah, that's the best answer yet.......I gave up toe shifting, from underneath, years ago. :)
PS Lived down the road from you in Boulder for about 23 years before moving on in 1980.
If you lube it you will be able to slide it off. Maybe you can get a smooth one to put on it. Or wrap it in brown leather to match your booties :)
A little humor there!!!!
This here from Warpo is your best option!
Because aluminum WILL also mark your boots!
Also, a GOOD quality pair of motorcycle boots (like my Daytona) will not mark!
EDIT:
I just now read that you are "refined".
Case closed, King! :thumbsup:
EDIT:
Thank you for your time sir it's very much appreciated.
