I've read conflicting advice on this matter, so can someone clarify for me? Here are the details:
2006 Rocket 3 Classic
TORS
CAT Delete
NO intake mod
Currently have TuneECU installed (map 20219 w/secondaries open to 100% and O2 Optimizer installed), and PCIII-USB (map 510-003).
Here's the question...should I have the PCIII running a ZERO Map right now until I get it dyno'd, or is it OK to have both the TuneEcu and PCIII running the specified maps concurrently?
Some have said the PCIII should have ZERO map installed, others have said tht the PC map is fine as long as the TuneEcu map is the correct map for my setup?
Can someone confirm which is correct, as I do not want to create a problem whereas one program is in conflict with the other. Thanks.
TORS
CAT Delete
NO intake mod
