Questions from a newbie without a manual
Discussion in 'General Tech Talk' started by Berber, Nov 22, 2017.
Tags:
  1. Berber
    Berber .040 Over
    Country:
    United Kingdom
    73
    56
    28
    Nottingham, UK
    Ride:
    R3 Roadster
    A few questions guys from a man without a manual (its on order from the dealership)
    What are TORS (I have to assume they are replacement exhausts for the Rocket)
    How do you remove the rear seat (don’t yet have a manual and cant see anyway to remove it)
    Would a one piece, two seater fit my current set up of a single seat and small separate second seat
    Any problems with bleeding the brakes yourself given I have seen the odd comment on here mentioning ABS and bleeding issues.
  2. Bernard Vinet
    Bernard Vinet Frenchbernie
    Country:
    Canada
    647
    423
    73
    Montreal Canada
    Ride:
    Rocket 3 Touring 2012
    Not sure but I believe it means Triumph Off Road Service parts. Not sure though. Opps and welcome from Montreal, Qc
  3. Simon Fioretti
    Simon Fioretti Big Chief Crazy Balls
    Country:
    Australia
    82
    Featured Threads:
    1
    120
    43
    Mount Gambier, South Australia
    Ride:
    Triumph Rocket 3 Roadster 2010
    TORS = Triumph Off Road System
    Remove seat by using ignition key to unlock the seat on right side of the bike there will be a lock top of the shock height
    Not too sure about twin seat I think they are interchangeable but not 100% I’m sure a more knowledgeable member will fill you in
    foxviewnet likes this.
  4. foxviewnet
    foxviewnet With foxes we must play the fox!
    Country:
    United States
    348
    Featured Threads:
    9
    Media:
    2
    474
    73
    Huntsville, AL (The Rocket City)
    Ride:
    2007 Rocket iii Classic 2006 Yamaha Vmax
    Hey Berber,
    On a Classic, you need to insert your ignition key in the right side cover just in front of the right rear shock and turn counter clockwise while pulling a tab ring just underneath the left side of the seat. It is close to the seat strap. Pull it out away from the bike. You will feel the seat release from the rear and it will pop up. raise the seat from the rear and pull away from the gas tank. The tab ring is plastic and may be a little tedious to find the first time and big hands don't help. I am not sure if your seat is exactly the same or not being a 2 piece. Seems like the single seat may not have the pull tab at all and the rear seat is attached to the mud guard with hardware.
    TORS is an acronym referring to Triumph Off Road Silencers.
    I am sure that someone a lot smarter than I am will come along and give you some tips on the ABS brakes. seat removal.JPG
    TURBO200R4 likes this.
  5. warp9.9
    warp9.9 Pocałuj mnie w dupę
    10,140
    Featured Threads:
    9
    Media:
    14
    12,092
    823
    Forest City Illinois
    Ride:
    07 Rocket
    Push down on the center of the seat before turning the key. On the dual touring style seat tjere is a plate that resembles the one on your little seat except it has a latch spike for the secomd rear pull ring fiscribed above. Let me get my coffee and il take a picture of it as I brought one with me for @Bearpaw to try.
  6. warp9.9
    10,140
    Featured Threads:
    9
    Media:
    14
    12,092
    823
    Ride:
    07 Rocket
    Ok if needef I can take a picture of it mounted on my bike if you need.
    But you will see this resembles what is attatched to your little pillon seat except you can see the latch spike.
    When running the dual seats for the rocket not the (R3T) this plate stays bolted to the bike.
    phar2slo, TURBO200R4 and foxviewnet like this.
  7. warp9.9
    10,140
    Featured Threads:
    9
    Media:
    14
    12,092
    823
    Ride:
    07 Rocket
    O so I just realize the picture fox view posted above is my bike and my hand :) Thought the shocks looked familiar.
    So hear a shot with the mounting plat bolted to the bike although by now you will have noticed it looks and mounts like your rear pillion seat does
    Yellow circles same mount bolts as yours. red circle the latch spike.
    picture of seat underside below yellow circles the latch mounts red circle the pull cord for the rear latch release
    phar2slo, foxviewnet and Big Gun like this.
  8. warp9.9
    10,140
    Featured Threads:
    9
    Media:
    14
    12,092
    823
    Ride:
    07 Rocket
    Also do a search for any post made by @idk.
    Summoned just in case he is around. He has the older manual in his signature. It has a lot of useful information. @1olbull can supply you with the roadster speciffic abs stuff via e-mail.
    Most times its easier to print the speviffic pages and toss them when your done with the work.
    lorich5 likes this.
  9. rocketjohn
    rocketjohn Top Fuel
    Country:
    United States
    1,934
    Featured Threads:
    7
    1,762
    323
    Roanoke, VA
    Ride:
    was a 2013 Triumph Rocket 3 Touring
    But it's so much more fun to print all ten thousand pages, and use up three containers of toner!
    lorich5, TURBO200R4 and Nat67 like this.
  10. Bearpaw
    Bearpaw .040 Over
    Country:
    United States
    63
    37
    28
    Rutherfordton N C
    Ride:
    2005 Rocket 3
    Brought one where for me to try ?
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
