Rocket3Pilot
Thanks so much for the explanation. I will order it now and try to learn how to use it! I'm sure I'll be back with more questions as I get into it.Reads faults and clears them. It will help you do test like tach, speedo, fan, fuel pump. You can correct the speedo error if you decide to. You use it to balance the throttle bodies set the TPS or change the TPS. It is worth it for the maintenance alone.
