I now own this bike and is one of the four Rockets I own.
The Triumph fly screen mounts are what is used for the mounting of this screen. There is a guy making brackets selling on eBay I think
@Ishrub would know this info.
I can take some pics for you but I do know that the brackets have been modified as the gauges were moved etc
Yep Dave Gill in the UK makes stainless steel versions powdercoated black in 2 styles - matching stock screen position and a customized version which brings the bottom tip forward an inch similar to Ponter's (now
@Mittzy 's) Bike above and allows easier access to your ignition lock and key etc. but you may have to drill some new holes in it to get exactly the orientation you want.
Easiest to buy on eBay through his toyota6510 used id or his online store called Rocke's Patches. Sometime he is a little hard to contact but great bloke.
Cheaper with better postage rates too at his Rocke's Patches site though for many of the same items but he does not restock or have the same range here for body bits anymore.
Triumph Rocket 3 Metal Parts - Rocke's Patches
Triumph Rocket 3 Plastic Parts - Rocke's Patches
He makes and sells quite a few things that may appeal like Fiberglass (GRP) Bearclaws (with vented grilles or not) and even a RHS dummy version for a similar look on both sides of your tank and FAR, FAR, FAR cheaper than Carbon Dry's fiberglass or similar versions of things.
TRIUMPH ROCKET 3 roadster rocket 111 rocket iii fly screen brackets custom | eBay
The brackets are made from stainless steel laser cut then power coated black , they are same fit as the original but been re designed to push the bottom of the screen 25 mm forward the pitch has been alter same rake angle as the forks to give more access to the key area slots for adjustment ,
Stock screen position matching version below
TRIUMPH ROCKET 3 roadster rocket 111 rocket iii fly screen brackets black | eBay
Black custom Chrome bolt kit.
TRIUMPH ROCKET 3 roadster rocket 111 rocket iii fly screen bolt kit in black | eBay
TRIUMPH ROCKET 3 roadster rocket 111 rocket iii Grp air box cover vented
TRIUMPH ROCKET 3 roadster rocket 111 rocket iii Grp air box cover vented | eBay
LH version here for replacemnet of existing Bearclaw.
