warp9.9
Pocałuj mnie w dupę
Oil and oil filter should be fine. It would be nice to change the fuel filter but the fuel recirculates so .uch it will probably was out quickly. I would pull the fuel line from the tank and the rail with the injectors just to dump the rail it probably was pinging bad do to the lowered octane. Taking the tank off is easy then you can stand it straight up and get most of the fuel out. Just lay a towel on top of the engine to catch the fuel dribbling from the line. The tank has a check valve in it so fuel will not come out when you remove the line. Oh and I've been using the same crush washer on my bikes since new. At least pull the plugs inspect and clean them.Have I damaged the bike?
How meticulous shld I be on cleaning her out? Am broke, but if needs be?
Oil and oil filter? Fuel filter? New plugs? Pull and drain fuel lines? Injectors? Any damage to engine likely ? :-/
