When it comes to the sump pan gasket I clean both surfaces and the apply grease to the gasket so it will stick. I don't use any hylamar or permatex as I do not want to chance any squeezed out gasket sealer to get into the oil system. Especially around the port gasket area on the two scavenger pumps. Grease helps hold the gasket in place I stick it to the sump pan and go up slowly until I can get a few bolt threads in on say 4 corners. then I install every bolt before going up so I know the bolt holes in the gaskets are lined up. If the motor was upside down it would be easier but its still pretty easy with the bike on the kick stand. although I put a board under the kick stand to stand her more upright. While you under there clean you crank pickup sensor!!!!!!
I've got some longer bolts for the corners to assist with alignment. Then will get a few threads on each bolt started before tightening.
Do you just run a cloth between the sensor & crank? What would I expect to be there, minuscule filings? a little glitter on the cloth?
Thanks for your input!
Scott
The brown truck should be delivering my sump today.
@warp9.9 I remember your advise about blue locktite on the screen bolts. But thought there was something you recommended about grease on one side of the gasket & gasket seal on the other. Maybe it was another poster, but I cannot find the thread now. Sooo,... do you put anything on the gasket to help it stick?
Thanks,
Scott
Does the service manual say to put anything on the gasket, if not I wouldn't.
Scott
Ya I wipe it off with a tough cloth so not fibers or fuzzy's are left behind. Shouldn't be much but heck your down there anyway its only one bolt.
No the service manual only goes over installing once the engine is out which is the long way :D
It's in the lubrication chapter.
Oil sump pan bolts Since your pulling it for a leak take a look at the sump screens for debris. there might be some machining Swarf left over but anything else should be looked at.
Got seepage on my 2010 Touring, thought it was from filter (alas NO) so gotta go down the gasket Rd. Is your pic 2010 style? And was wondering about the 3 screws on the inside of the perimeter 18, are they a different size and do they need to be undone to drop sump.
Also what is the tightening sequence.
