RockOn
Turbocharged
- Joined
- Feb 22, 2018
- Messages
- 635
- Location
- Escondido, CA
- Ride
- '06 R3 Classic, '08 R3T, '15 R3 Roadster ABS
After adjusting my headlights upwards and my windshield to it's max height I was about to roll the ballistic missile back into the silo when I saw two wet trails going down the front left side of the engine. WTF? I had only idled the engine briefly a couple times within an hour's time frame while adjusting the lights and shield. Then I saw a tiny green puddle at the end of the two narrow streams still clinging to the lower outer ledge of the engine cases.....suspended and not yet airborne. The small lower coolant hose clamp was tight as it could be and then hoping the upper larger hose clamp was the answer I was very pleased to find it loose as a goose or nearly so.
Sometimes luck is the lady and it was today. It could have happened during a long ride and later discovering my pant leg and bike sprayed with coolant or worse.......out of coolant. So, a small ray of sunshine perhaps but I am very stoked I discovered an easily fixed problem before it became a big problem. As they say.....timing is everything, or nearly so.
Hoping everyone has Happy Holidays!
