No more chrome
I fixed sat nav on using ram mount fixings,where the clocks are bolted on,remove bolt and replace with ram mount ball fixing ( Aluminum 1" Ball on 1/4 NPT Female Thread RAM Part: RAM-B-218-1)
then attach ram mount arm to ball ( RAM U-Bolt Mount (Aluminum) RAM Part: RAM-B-149 )
fix sat nav holder to bracket
you can find all the bits on ram mount site, this is the uk site,but there will be a site in your country i'm sure
RAM Mounting Systems UK - RAM Mounting Brackets
hope this is of some help
andy
Hey Andy, two more questions:
1) It took me awhile but I think that I found the ball that you say is the B-218-1. I believe it is the B-367 instead. You can see it here: RAM Motorcycle Handlebar Clamp Base with M8 Screws
I've ordered one so I'll confirm if it's right.
2) In your 1st pic, there is another chrome screw that looks to be between the gauges. If I might ask, what is mounted to it?
thats just a bracket i made as i had to move the clocks forward because of the handlebar i fitted,the screw you can see is holding the clock (hours/mins) i fitted
