Frederick45 .020 Over Joined Apr 22, 2022 Messages 14 Ride Triumph rocket 3 classic Aug 15, 2022 #1 I have to give my bike a little throttle to start it no idle
Gerald Turbocharged Joined Dec 14, 2018 Messages 935 Location Lou. Ky Ride 05 Rocket III Aug 15, 2022 #2 Frederick45 said: I have to give my bike a little throttle to start it no idle Click to expand... Check primary tps, requires Tune ecu and connector cable. Many other causes for this, just a place to start.
Pedro Turbocharged Joined Oct 13, 2007 Messages 614 Location Rockingham , Western Australia Ride 05 TTS , Lush Rocket standard Aug 15, 2022 #3 Check to see if the stepper motor linkage is connected to throttle and is being activated. May also be Primary TPS needs resetting or replacing
idk Living Legend Joined May 16, 2008 Messages 5,907 Location Maryland Ride BMW R1200C Aug 16, 2022 #4 Probably TPS. Check that it is set correctly, if not then set it correctly. If it goes out again then it'll probably need replacing. Also, spray some WD40 around the throttle linkages to thoroughly clean them as that can also cause the problem.
