Bruzer05
Standard Bore
- Joined
- Jan 20, 2014
- Messages
- 6
- Ride
- 2008 Rocket III
That's a YouTube link to my video of it trying to start. Previous post of mine was in 2014 soon after I had acquired the bike. Starting issue continues, even after a recent battery replacement completed by the shop. Have done several things over the years trying to get this thing running consistently. Tank was refinished on the inside by a shop due to corrosion several years back. I installed the Eastern Beaver headlight bypass kit. I installed an 8 gauge extra grounding wire to the frame. New battery prepared and installed by shop last week. I sanded the battery connections after the install to ensure a clean connection. This is just frustrating me to no end; I cannot reliably ride my bike. Sometimes, it will crank and crank and start. Other mornings, it will crank and crank and die.
Video Description: Continuous filming, no cuts/breaks. Turns over, but no start until 30 seconds into the video. Once it starts, I let run for about a minute, then shut down. It then re-starts no issue. New battery, 310 cranking amps. Weather in the 60s. Only sat for about 22 hours since last ride. Did basically same thing even after being on battery tender all night.
My previous post about the bike:
Litany of issues: no start, CEL, wiring possibly modified
History: 2008 Rocket III. Bought used from a small HD dealer in June 2013 while moving cross country. I should have been cautious because the check engine light and gas gauge light were on. Soon after, it had trouble starting. Would crank over several times before ignition, and once start...
