My Rocket turning into a Harley ,,,,,,help,,,,
Throw a fuel stabilizer like STP in the tank and check air filter for proper fit/flow. It's choking on something, so it's either not getting enough air or not enough fuel (or potentially too much fuel?). Every once in a while I have a similar issue, and I think it's just this $hit fuel we have to use nowadays. Like I said, run a bottle of stabilizer through a tank and see if the idling/response smooths out.
Just assuming that the Mexican has a bunch of lawn mowers sounds a bit racist.
It certainly wasn't meant to. I was going to suggest that he put a bit at a time in his trucks' tanks, but I didn't think it would mix too well with diesel.
It could very well be the TPS is out of sync with the ECU and dumping more fuel then needed. I would definitely hook Tune ECU up and run some diagnostics and a ISCV. If it returns to normal keep a eye on it as the TPS might be getting worn in some areas. Also like Ian said look at the vac lines and stuff near the filters which you just changed to make sure you did not disturb something. I doubt you did as it would throw a code in the ecu.
hey guy why don't you buy a fuel pump tester for the rocket and then we can borough it when we need one
if it is the fuel filter it should not affect it at idle. also if you have crap in the tank it usually works ok at first then gets worse as you drive more.
when a bike backfires it sometimes blows off the vacuum hoses. this makes the map read wrong. you can check the exhaust system by removing the 02 sensor or backing the bolts off a little to create a gap. don't lose your nuts when you go for a test ride.
if you just blip the throttle does it sound ok?
The bike backfires on decel, wont lose my nuts sincs i wear kalvin klain, ha ha, and @breeze, dont think the clutch is slippin
