warp9.9
Pocałuj mnie w dupę
Ya I have anoth plug and complete cover. Figure I might as well update to the bilet clutch basket and MTC fibers.You let someone else work on your bike???
Risky business, doing it with engine running. I'd sooner get that port cover off even if I had to bust it and replace it
Anyway yes the Titan was built by Carpenter not me. It had the 240 kit in it after the blower/multiple crankshaft problems. I bought it because the feller needed the money. Its neen back there and had the valve spring update so no duals. I called the shop when I first noticed the problem. (When I went to check the chain and couldn't) he walked me thru adjusting it at idle. Another thing i figured out is if you leave her in gear and roll pressire forward and constant you can take up the chain tension and adjust it without the inspection plug open. The key is the feel make sure you hook that O-ring and pull it out a few threads so there is no friction. Something you do not have to do with Nevs. Again Carpenter does mot make one they use the APE. Anyway put almost 20,000 on the engine and really hasn't been alot of tensioner adjustment needed.
