Let the frustration begin!!!! grrrrr
Ok...just went for a ride, still having issues that seem to change every time I ride the bike, which leads me to believe something electrical, like the TPS is acting up...
Couple thoughts and concerns...
1. I screwed up and loosened up the secondary TPS instead of the primary. It was marked with paint on where it was set before so I put it back...would having the secondary tps off slightly cause issues?
2. I don't have secondaries...so does the secondary TPS even matter (not sure the secondary TPS even controls the secondaries but wanted to mention it)
3. I don't have the tightening clamps on my ramair...they seat pretty tight without the clamps, but could this potentially cause an issue?
4. How can I tell if my TPS is bad...?
I have double and triple checked my ISCV test...my throttle bodies are dead on.
Where should I go next other than the nearest lake? lol
Update. My secondary tps won't adjust at all. It's stuck between .65 to .66. No matter how much I move the sensor it doesn't change.
And as I messed with the secondary tps it threw this error code below. It cleared fine made a bunch of buzzing noises but still won't adjust.
My secondaries are removed and appear to be controlled by this sensor.
Could this even effect anything since they are removed?
I also wanted to report that when the bike gets into this stumble mode, it pops on decel very badly for moment and then comes back to normal...I would assume this means it's running rich for a moment? I'm really leaning toward one of the TPS sensors acting up BUT before I spend 140 bucks I was hoping for the experts to chime in...
