Jabo75
Eschew Obfuscation
- Joined
- May 11, 2014
- Messages
- 287
- Location
- Pittsburgh, PA
- Ride
- 2005 Rocket 3, 2010 Electraglide Ultra CVO
BTW Took mine off and sprayed a few short blasts of brake cleaner in the TPS and linkage. 1 drop of WD4 in the TPS and clean with a Q tip. Some WD4 in the linkage. Replace and calibrate to .60. O2 sensor off. Runs like a charm. Both sides are dry and even lets me have neutral easy, most of the time.
Next, the Yokes. Seals, springs and adjust the front to specs.
When you say "sprayed a few short blasts of brake cleaner in the TPS and linkage", did you mean the TPS or the stepper motor? If TPS, you really should clean up the stepper motor (especially inside the rubber boot).
