Mark Dunn
.060 Over
Hi all,
I have a 2009 RIII standard with stock exhaust and airfilter. I'm running the Wayne Tripp Tune for TORS and underseat K&N as Wayne told me that it would work fine in a standard set up, - which it does, although likely marginally rich in places. I will be fitting D&D slip-ons shortly so the map will probably fit the set-up better.
The OEM map for the bike is 20222 and in comparing it to the Tripp map in TuneECU I see that the timing is identical in all ignition tables. From reading on this forum I believe that many people use TuneECU to copy the ignition table used in 4th and 5th into 1st, 2nd and 3rd. My question is, is this worthwhile and how is it done? Is it just a matter of copying the I3 table into I1 and I2?
All replies appreciated. Thanks!
Best regards,
Mark Dunn
Best regards,
Mark Dunn
