CanberraR3
- Joined
- May 27, 2010
- Messages
- 11,344
- Location
- Canberra, Australia
- Ride
- Triumphs, but no Rocket just now.
Well I just went and looked. The chrome cover comes off easy enough and if need be I could shave a mil or 2 off the edge. The reservoir sits almost an inch inside the outer edge of the cover on a bolt that has about 1/2 inch of adjustment without changing anything except putting a spacer in. That would move the reservoir out 1/2 an inch and may be all that's needed. There's a small heat shield on the inside of cover and it should be easy enough to pack that with something like exhaust wrap to protect the plastic. Completely doable I reckon. I'll go down now and take some pics.
Edit: as can be seen in the pics below, it's not a simple matter to shave a bit off the chrome cover due to the heat shield but at worst it would rest against the pipe or could be bent a little. The bolt holding the reservoir is pressed in but a longer bolt could be put in it's place after a little persuasion. Can't see any reason why the header won't fit.
I'll let you know how it goes!
