warp9.9
Pocałuj mnie w dupę
You can add a special hidden cable pull in place of the front key one if it does not work just hide it so know one knows where it is.
Also sorry it took to long but I have been very busy.
Anyway after releasing the back like others reccomended I found you can release the front with along straight blad screw driver. you will still have to push down in the center of the seat so block the back up so it does not relatch.
firts two pictures 1 with front latch closed and the second with my finger pushing it open.
this next one is with the straight blade long screwdriver in place for operation. remember when you do this you will still have to push down in the center of the seat a little up the arch.
last is with a scope and the screw driver so you can see you can actually get at it with the seat on it. I tried it several times and it works.
hope this helps if it ever happens to you again. I would look at cable adjustment or maybe bending the arm the cable hooks up to to make the cable pull take up the slack earlier. Cable adjustment should be looked at first maybe down by the key lever.
