Home made vaccum lines?
i'd get hoses the same length and internal diameter as the stock ones. if you had longer hoses, that's more volume to draw the air out of to obtain the same level of vacuum which will upset readings for throttle balancing and MAP readings to ECU. but you'd need to be significantly longer though, so just to be on the safe side
Will do that, :)
