Hi all,
I received my Hagons from the Group Buy last Wednesday and with only a minor tussle I managed to fit them to my 2009 R3 standard. The Hagons replace Progressive 440s which have worked pretty well for the 18k miles they been on the Rocket.
Since I'm only 182lb soaking wet, I left the spring compression as set from the factory and dialed the rebound damping up one click. I've done about 160 miles on them so far and they've pretty much settled in. To cut to the chase, the Hagons are a big step up from the 440s. The ride is smoother overall and generally feels much more 'planted', especially in the curves.
I took the old ball and chain for a ride this morning (on the R3, that is) and the improvements with a passenger are even more obvious. She says the ride is far better too. Naturally, I'll continue to experiment with settings to see if there's any more to be had from them but even if there isn't, I'm well pleased with this purchase.
Thank you Wayne for putting the Group Buy together!
Regards,
Mark Dunn
