Frosty Rider
Turbocharged
- Joined
- Nov 24, 2016
- Messages
- 799
- Location
- Toronto, Ontario, Canada
- Ride
- 2010 R III T, 2020 R 3GT, 2001 HD CVO WideGlide
Good Day, well for some i guess, I have the RIII Touring, and i get an intermittent miss fire, i'm at a loss, I have been fighting with this bike for over a week chasing down electrical issues, finally got them all, but this one is killing me, so far i have done
Changed Cam chain guides, Cam chain, Valve adjustment, needed to re-shim 6 valves, that was fun
verified that the timing is all correct, Crank and Cams line up perfectly
New spark plugs, and ignition wires, and tightened up the connects on the coils
chased down electrical issues after putting it all back together, a couple of blow fuses, changed relays, previous owner installed power commander, turns out the black and grey blocks under the tank get swapped, ie: the black connectors go to the big grey ones, instead of black to black and grey to grey, good times
sorted out the no start, turns out the security fob needs to be next to the bike, not 2-3 feet away, that was a hard lesson
got the bike running YAY, but while idling, it would be running ok then suddenly there is sort of a half a second skip where there is no firing, and then it kicks in again, or it will just stop, i can start it right up after, but it will do that every few minutes
I reflashed the power commander and the bikes ecu using the tuning from Hanso that i have been using since i got the bike, let it do the whole 12-minute run after flashing, and it would still do this during the 12-minute run, but didn't die.
took it for a ride and i can still feel a miss in it, i'm at a loss at this point, checked and all plugs are firing, i haven't ruled out a weak coil yet
