dr.P.O.N.
Hi everyone.
My 2008 R3T is driving me nuts. She works perfectly on idle, but misfires start as soon as I open the throttle. Doesn't matter how wide the throttle is open, engine keeps stuttering, backfiring and all that.
The setup is Ramair/TOR/Nels tune.
I've thrown in new spark plugs, new ignition coils. Air filter is clean. Tried different gas stations. Nothing helps.
TPS sensor seems to be fine. TuneECU shows throttle position steadily in all of the range.
Could this trouble be caused by faulty ignition wires? I'm ready to replace those too. Would hate if this wouldn't help either.
Also, I've noticed that the primary stepper motor is behaving erratically. When testing it with TuneECU TPS voltage on closed shows 0.62V (which is within limits), yet during the second stage of testing (open) the voltage keeps jumping from 0.72-0.74 down to 0.6 and even below that. The motor itself is not humming steadily but keeps screeching. I don't believe this should be a normal behaviour.
However, as far as I understand, the stepper motor should be affecting only idling, and not open throttle modes. Correct me if I'm wrong.
Anyway. I'm banging my head against the wall here, so suggestions and thoughts would be appreciated.
