Hi All, Been having erratic idle and stalling as of today om my 2012 Roadster, always fine in gear, but going back to neutral would make idle drop and almost cut out, all 3 cylinders. No codes, Idle speed control motor working, Gear indicator on Tach reading correct. Bike runs great except in Neutral, Unplugged indicator switch behind left filler panel and all is WELL, dead smooth. All grounds tight, all connector plugs checked along with pin to pin contact in the connectors for the indicator switch. Bike has 5,940 miles. Guess its new indicator switch time, out of the 2 year warranty. Anybody else had this fail so soon? Is this 2012 restricted in the first 3 gears on timing advance? Bike Has newR3.com Mufflers, Dobeck series 3 controller, triple K&Ns, secondaries removed. Throttle bodies are clean, unplugged Idle stepper motor and it made no difference, still cut out until I unplugged the gear indicator switch. Do not have tune ecu or tune boy yet, using my OBDII scanner to clear the codes, gives me some info. Thanks, Bill
